Dumb/general question. How do I change my door speakers?
Yeah i know how to change the door speakers, but i was wondering if I would be best off pull the entire door panel, or if the speaker grills themselfs actually come off.
If I need to pull the door panels, a quick step by step would be awsome, i have a tendency to break things (such as door clips) when I dont know how to do somthing.
If you have the bose panels the grills do not come off. Just use a small flat head screw driver and pop the slide lock peice out of the hole. There will be a screw/bolt there. Take that out then just pick up on the panel. There isn't any clips to wory bout. make sure you take off the lil triangle peice at the top corner of the door first. It does have clips so be carefull. Then the speakers should just pop out. That should be pretty close, it has been a while since I had my panels off, plus I have had a lil bit to drink but that should be everything.
Here for 03 to 05
http://www.humanzoom.net/gmfs/tech01.html
Here for 99 to 02
http://www.jsmithlm7.com/silverado/index.html
Now they work
Here for 99 to 02
Now they work
Originally Posted by blue 01
Here for 03 to 05
Here for 99 to 02
Here for 99 to 02
When I took my doors out here is what I did. Took off the triangle piece by the mirror, popped off the lock, popped off the window controls and unhooked them, popped off the thing around the door handle, undid the screw thats behind the lock and under the armrest, lifted the door panel off and had a friend unhook the door light at the bottom and that was it.
Just be careful of that door light, I had it hanging there and closed my door on it. Its not that big of a deal but just something I thought I'd tell you to look out for. good luck with everything.
Corvette454l88
Sep 1, 2016 01:24 AM
RJaxtheimer
Oct 31, 2015 07:58 PM
