dual batt set up.
Old Jul 25, 2010 | 06:40 PM
sierra69's Avatar
Talking dual batt set up.
is there a wiring diagram for a dual battery set up for my 2007 newbody crewcab sierra?
Old Jul 27, 2010 | 08:07 PM
mhotrodscooter's Avatar
Check out the durmax it comes with 2 batteries
Old Jul 27, 2010 | 10:04 PM
53bowtie's Avatar
what do you mean by a wiring diagram?? You just hook them up in parallel. If they are not the same battery you may want to put an isolator between them.
Old Jul 27, 2010 | 10:28 PM
Krazy Ken's Avatar
Yeah if you don't run parallel and instead run negative to positive you will actually create a 24 volt system which will fry alot of things. so make sure you hook up correctly. Did yours come stock with two or are you adding one like i did?
Old Jul 27, 2010 | 11:31 PM
i believe it is---series, makes it 24 volts, but same amps
parallel, same voltage, double the amps(assuming identical batts)
Old Jul 28, 2010 | 12:03 AM
Atomic's Avatar
I have a gauge for that
Yea, things in series see the same current, but add voltages. Things in parallel see the same voltage, but add current.
mzoomora
Jan 3, 2016 07:06 AM
truefire04
Oct 18, 2015 04:38 PM
Castro45
24
Jul 31, 2015 07:13 PM
kdw8888
Jul 9, 2015 10:52 PM
01sierraon22s
Jul 8, 2015 11:26 AM
