downfiring SUBS / Where put amp?
Old Dec 20, 2006 | 06:15 PM
dropkick13's Avatar
Default downfiring SUBS / Where put amp?
im building a box for two downfiring 10" subs to go underneath my back bench. space is a huge concern (each sub needs .75ft^3 total). how much space need be made available to keep the subs from flexing into the floor? (gap between cone and floor).
Also, my amp is going to take up a lot of space (2ft x 1ft, weighs like 30-35lbs). where can i put it? right now i can only imagine putting it on the hump between the 2 subs, but it pokes out and this makes me have to build two separate sub boxes (less volume per sub)
Old Dec 20, 2006 | 06:37 PM
SaintLos's Avatar
Depends on the type of sub...Most likely need at least an inch between floor and sub.
You could try mounting the amps behind your rear seat for a stealthy install. Get creative.
Old Dec 21, 2006 | 06:39 PM
SmokedSierra01's Avatar
Mount the amp behind the back seat it leaves room. I have 2 solo barac L7 in a downfire w/ cap and big amp behind the seats. Don't worry about airspace, you drive an ext. cab truck and dont' have **** to work with in the first place. The few inches you lose make no difference.
AHelm3
Apr 8, 2016 07:51 AM
mzoomora
Jan 3, 2016 07:06 AM
Bluchevypick
Aug 18, 2015 09:11 AM
00pooterSS
Jul 16, 2015 03:03 PM
00pooterSS
Jul 16, 2015 02:41 PM
