Best harness for electric fan retrofit?
Who makes the best harness to tie into my 2004 Silverado with some LS1 fans? I've found a couple online but wanted to get some opinions.
Thanks
Thanks
4ws f 7 (08-15-2020)
junk yard
The nelson provides the best current capacity and higher quality wire and relays and even grounds vs stock.
The biggest issue is normally people dont upgrade the alternator and do not change the tstat at the same time. Most trucks with the fan clutch have the lower output alt. Upgrading that as well as the anemic power cable from the battery junction box helps out significantly.
We will be working on a heavy duty hybrid with upgrades that includes everything needed but is alot cleaner than the nelson harness.
still running my 105 amp even though I have a 140 sitting on the shelf
I added them on all 3 of my 2500hd trucks (2 gmt800s and a gmt900) with 6.0s. 2 of them have manual windows but the gmt900 has the higher output alt stock. They ran fine without much issue until both fans and ac were on then the voltage level would crash and sometimes idle funny too. Even at night you could see the lights dim. Changed to the 140/5 amp alt and no issues since. The voltage is much more consistent and batteries last longer for me. I put all of my trucks through hell from hauling heavy loads to getting stuck in the mud etc. Thats what 3/4 ton trucks are made for though right?
Bumping the idle speed does help also but all my trucks idle at the stock speed (550 - 600).
I think my alternator has been changed
