Autometer Gauge ?'s
Old Jan 19, 2006 | 10:05 PM
Wilde Racing's Avatar
How do I change this text
Originally Posted by sikchevy
i went and bought some gauges today and have a few questions. the oil temp and oil press didnt come with any lines or wire. the water temp came with about six feet of line which has the temp sensor at the end of it. so i need to know how many feet of line and wire i need, and any other misc. things i will need for the install. ive never done gauge installs before so any tips would be cool. here are the gauges with the p/n's i got.
atm-4332- water temp, 120*-240*
atm-4327- oil press, 0-100 psi
atm-4347- oil temp, 100*-250*
.... these are the part numbers from summit
Do any of the gauges have sending units? or do you have to run plastic hose to the back of each gauge?
I looked at the gauges on-line, but it looks like they are all mechanical.
Old Jan 20, 2006 | 05:42 PM
sikchevy's Avatar
i will check them when i get off work. i know one of them does, but cant remember which one.
Old Jan 21, 2006 | 03:32 AM
1FUNZ71's Avatar
14 Second Truck Club
Dusty,
Try to get over here to Fallon and let these guys have a ride in the truck. Give me a call.
Erick
Old Jan 21, 2006 | 10:21 PM
sikchevy's Avatar
the only gauge that really had anything is the oil pressure gauge. it came with either a sending unit or pressure regulator. i cant tell what the hell it is. they are all mechanical, so i guess i have to run plastic hose to the back of the gauges?
Old Jan 22, 2006 | 01:23 AM
I am kinda suprised nobody has answered you questioned. First of all you water temp is a mechanical gauges this why you have a tube that came with it, your other 2 gauges are electric gauges. Electric gauges do not require any kind of tubing, they do requre a piece of 14-18 gauge wire running from the sender to the back of the gauge, a 12 volt ignition source and a ground. This will make the gauge part work but not light up. As for the water temp send it back and get an electric gauge, part # atm-4337.
Old Jan 22, 2006 | 04:16 PM
sikchevy's Avatar
solid answer, thanks
simman22
Jan 21, 2017 10:27 PM
dantheman1540
Feb 24, 2016 09:56 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Lthompson
Oct 2, 2015 12:45 AM
97_ek
Sep 23, 2015 09:16 PM
