Anyone familiar with gmt800 fuse block?
Old Nov 16, 2016 | 10:41 AM
mvrk10256's Avatar
I used a standard bar fuse from the breakout on the front left firewall.
Old Nov 16, 2016 | 10:55 AM
tpartsman's Avatar
Default Match in line fuse to amp fuse
Originally Posted by GM1697
Awesome you're the man.
Although after researching it seems the lowest amp you can get those fuses is 100a... seems like overkill for one amp... maybe my idea isn't as good as I thought.
You want your under hood fuse right around a foot from the battery you want that fuse to match your amp, ie if the amp takes two 40 amp fuses you should have an 80 amp under the hood. I had my wire hidden in the fuse box but it is a pain to get at if needed.
