aftermarket radio wiring harness, please HELP!!
Old Mar 28, 2010 | 02:55 PM
burninrubr's Avatar
Default aftermarket radio wiring harness, please HELP!!
Ok, i have an 03 RCSB, i am trying to install a new radio, stock one likes to eat cds. I am trying to find the correct wiring kit to do this, the first one i bought does not fit (GWH-344), so i found another one at wal mart (scosche gm035), it plugs in but the terminals are all in the wrong spot! Does anyone have a part number i could use to finally find the correct plug?!! i checked ebay and all the ones i see for 03-05 are like a hundred bucks, WTF!!!
PLEASE HELP!!!! ASAP!!
Old Mar 28, 2010 | 02:59 PM
burninrubr's Avatar
http://cgi.ebay.com/ebaymotors/Car-R...fAudioQ5fVideo
is this what i need? becasue of RAP, and the chime im guessing?
Old Mar 28, 2010 | 03:06 PM
Black'Rado's Avatar
DO NOT USE walmart harness....they suck and are almost always wrong. Go get one from your local audio shop
there are a few different harnesses you could use depending on if you have bose, onstar or both.
yes the harness are about 80-150 bucks.
If you dont have bose or onstar, the harness is jus called gm-chime.
there is away around using the expensive harness but i dont recomend it if your not comfortable with messing with wires under the dash.
Old Mar 28, 2010 | 03:12 PM
Black'Rado's Avatar
gmrc-01 should be it
Old Mar 28, 2010 | 03:41 PM
burninrubr's Avatar
thanks for the help, and no onstar nor bose. dont really feel like messing around under the dash. i cant believe they are so expensive for these trucks!! its outrageous! thanks again!
Old Mar 28, 2010 | 03:46 PM
Black'Rado's Avatar
the harness for just chime and swithched power that you need is the cheapest one, i wana say around 80 bucks or so. maybe cheaper if u get it online.
Old Mar 28, 2010 | 03:56 PM
outlawz2004's Avatar
You can use the walmart harness, move the one pin I believe is all you need to move to another spot, and add a wire from the fuse box. Nothing to it, and save yourself $70.00.
Old Mar 28, 2010 | 04:18 PM
el_cabby's Avatar
yup harness rom walmart works just need a switch power source from ur fuse box to red wire from aftermarket radio
Texas5.3_1251
Mar 5, 2016 08:10 PM
97gmc
22
Sep 8, 2015 10:56 PM
jleews6
Sep 8, 2015 10:17 AM
muncie21
Sep 7, 2015 09:55 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
