aeroforce question...
Old Jun 1, 2008 | 09:44 PM
andrew383's Avatar
traveling mod
Default aeroforce question...
you guys that are running the aeroforce where are you hooking the hot wire to?ive got mine mounted it the overhead console and im hooked up to the power wire for the map lights but i wana hook it up somewhere else....
Old Jun 1, 2008 | 10:18 PM
shupe's Avatar
Default aeorforce
Didn't need a hot wire for the aeroforce on my 99 silv. Guage was powered froom the ODBII port.
Do you need the 24v + to bring in an analog input? Dont remember without looking it up.
Ran my wideband from the cruise control ciruit. If you need 24 its as good as any.
Old Jun 1, 2008 | 10:34 PM
Black-Jacket's Avatar
no, didnt need it in my 01, obd II and good to go
Old Jun 1, 2008 | 11:09 PM
thunder550's Avatar
High on diesel fumes
My gauges required a power wire. I ran it down the A pillar and into the fuse panel.
Old Jun 2, 2008 | 02:43 PM
02BlueStepside's Avatar
Old Jun 2, 2008 | 09:33 PM
andrew383's Avatar
traveling mod
mine didnt do anything when i plugged it in i had to run a 12v power wire for it....
Old Jun 2, 2008 | 10:57 PM
humm wonder why that is?,
Old Jun 3, 2008 | 12:35 AM
thunder550's Avatar
Maybe different versions of the gauge?
Old Jun 3, 2008 | 09:58 AM
FL-Pirate's Avatar
10 Second Club
I have the aeroforce gauges in my GTO and they were plug-n-play w/NO power wire needed. Must be different versions - GL
Old Jun 3, 2008 | 11:53 AM
ajt86's Avatar
check for power on you orange wire of the DLC
or if you have a scan tool hook it up and see if it powers up- if not check the DLC fuse
andrewlong
Nov 9, 2016 09:38 AM
andrewlong
Sep 8, 2015 10:25 PM
Bluchevypick
Aug 18, 2015 09:11 AM
Gotcha
Mar 28, 2008 11:58 AM
shupe
Jul 14, 2007 08:46 PM
