Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
NEW Product Release: Hi-Tek Deep Transmission Pan for '07-'17 GM SUV and Truck 6L80E
Old 02-23-2017, 05:08 PM
Former Vendor
B&M Racing's Avatar
Default NEW Product Release: Hi-Tek Deep Transmission Pan for '07-'17 GM SUV and Truck 6L80E
Application: GM SUV and 1/2 ton Trucks w/ 6L80E transmission
Description:
This B&M Hi-Tek deep trans pan is designed for GM SUV and 1/2 ton Trucks with the 6L80E
transmission. The pan adds 2.0 US quarts of additional fluid capacity and boasts an over 30
percent improved cooling efficiency over the stock transmission pan by using a proprietary
high quality cast aluminum. The Hi-Tek 6L80E pan also incorporates external cooling fins
which not only look good, but are also functional by increasing the surface area to help
dissapate heat much quicker than the OEM stamped steel flat transmission pans. Additional
features includes an engraved B&M logo, a magnetic drain plug for catching ferrous metals,
a temperature sensor port and stainless steel mounting hardware. Does not fit Camaro
6L80E trans
. Gasket and filter not included.
Please call 707-544-4761 or visit www.BMRacing.com for additional application and product
information.
• Increased Cooling Effect
• Engraved B&M Logo
• Additional Fluid Capacity
• Magnetic Drain Plug for Easy Servicing
Old 02-23-2017, 08:23 PM
jtphelps289's Avatar
Finally!! How much are they going to run?
Old 02-24-2017, 07:01 AM
CF7GO's Avatar
Do they clear aftermarket off road y pipes?
Old 02-25-2017, 09:50 PM
91LT16SpeedFormula's Avatar
Probably close to $250 like the Camaro pan.
Any truck fitment pics by chance?
Old 03-02-2017, 10:26 AM
Former Vendor
B&M Racing's Avatar
Here's a link.
Hard to say. We'd have to see a picture of your specific setup to know for sure.
Old 03-02-2017, 11:48 AM
CF7GO's Avatar
Originally Posted by B&M Racing
Here's a link.
Where the Y-Pipe runs across the pan....is it any closer than the stock pan? I had to modify my Off Road Pipe to clear the stock pan....My guess is it doesn't clear.
Old 03-02-2017, 06:56 PM
Former Vendor
B&M Racing's Avatar
If your Off-Road pipe clears the stock pan, it should clear our deep pan. Here's a pic that may help you out.
