LS1 Engine Harness
Performance Trucks Sponsor
Hello Guys,
I'd like to introduce our NEW LS1 Engine Harnesses. Here's a sneak preview of what you can expect.
LS1 Harness Pictures
The quality is top notch and the best design and assembly we've seen.
That's one reason we decided to build these, to offer a cleaner, tighter fitting harness.
-Every harness is covered in high-temp heat shrink or high-temp wire loom.
-High-temp TXL automotive wire
-Every terminal is soldered-ensures connection will never fail!
-OEM weather tight connectors
-OEM wire coloring for easy identification
-Tested before we ship so there's no second guessing the harness
-Easy installation
-Easy hookup, one ground wire, one battery wire, one ignition wire
-OBDII diagnostic connector
-SES light
-Speedometer and tachometer signal
-Custom lengths (ie O2, maf, vss, pcm location)
-Weather tight fuel pump relay w/ 12g wire
-Labeled connectors
-Options available - custom length, configuration, electric fan control, pass-thru firewall connector (one of the first we've seen, allows you to mount the pcm in the cab by using a weather proof connector)
-Oxygen sensors available
-Custom programming available
This basic harness is $550 and fits any LS1 engine with a standard transmission. Add for automatic, integrated fan harness, and custom lengths.
We guarantee this is the best looking, tightest fitting harness available!!!!
Every harness is test fired before it's sent out, this ensures your harness is 100% trouble free.
thanks,
Allen
-Easy installation
-SES light
-Labeled connectors
thanks,
Allen
We can make one for the Radix, it'll be very close to the truck harness. However, it won't be a direct factory replacement.
The pcm can be mounted anywhere in the engine bay, or some push the connectors through and have it in the cab under the dash.
The LS1 harness is almost done!
The harness doesn't include the coils, just the main connector.
thanks for considering us as your harness supplier.
Coming soon, alternator power wire, starter wire /relay and battery cables.
thanks,
allen
thanks,
allen
