Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
Gears, Posi's, Lockers, Bearings, Axles, More!
Old Aug 11, 2010 | 12:04 PM
  #81
RONS MACHINING SERVICE's Avatar
FormerVendor
Originally Posted by twolow02fransen
do you carry motive gear?
Hello, yes, we offer the full line of Motive gears.
Thanks
www.ronsmachiningservice.net
Old Aug 11, 2010 | 01:05 PM
  #82
FormerVendor
2006 Silverado SS which Has a factory 14 bolt 9.5 SemiFloat. I am looking for Left and Right Rear axle shafts??? Are these avalible or do I have to get them from a dealer??? Do you know if they are interchangable side to side or is one side longer then the other???
Thanks for your time Rons Maching Service
Hello, unfortunately we do not offer these axles. They are probably a dealership item.
Thanks
Old Aug 11, 2010 | 09:16 PM
  #83
1FastBrick's Avatar
Custm2500's Rude Friend
Thanks
Thanks Ron!
How about old body style 88-98 14 bolt 9.5 axles with 6 lug pattern. Would a company like yukon or somebody stock an axle blank and be able to cut it to length. I know they had different lengthes through out the years. I can modify the housing to use the larger old style bearing. I know its not cost effective idea but It can be done. I just need to know if the axle can be made.
Old Aug 11, 2010 | 09:58 PM
  #84
black00chev's Avatar
Slowest turbo build ever!
Hey, few questions...
First, what brand gears do you have/use? Also, what would be the price of front AND rear 3.73s/truetracs/and everything to assemble? lastly, cost of just gears and just truetracs. i work at a dealer so some of the install stuff i might be able to get a hair cheaper.
Thanks much!
Old Aug 12, 2010 | 01:37 PM
  #85
1_fastsilverado's Avatar
Hey Ron, I want to place my order online, but want to make sure I'm buying the right stuff. I want a detroit trutrac, motive 4.30 gear set, master install kit, and axle bearings and seals for both sides. It's a 1500 with rear disc brakes, I saw on the site where it specified. Thank you, look forward to placing this order.
Old Aug 16, 2010 | 11:51 AM
  #86
FormerVendor
Thanks Ron!
Hello, we can get GM 9.5 6-lug axles that are 33-1/4" and 31.5", but no blanks.
Thanks!
Old Aug 16, 2010 | 11:59 AM
  #87
FormerVendor
Thanks much!
Hello, we offer USA Standard gears, Yukon gears, and Motive gears. We can offer the following packages with USA Standard gears:
1- GM 8.5 3.73 gear
1- GM 8.5 Truetrac
1- GM 8.5/8.6 master install
1- GM 8.25IFS 3.73 gear
1- GM 8.25 master install kit
Free shipping
Total: $934.99
1- GM 8.5 3.73 gear
1- GM 8.5 Truetrac
Free shipping
Total: $799.00
Just so you know, a 4.11 gear package will be about $150.00 cheaper.
Thanks!
Old Aug 16, 2010 | 12:01 PM
  #88
FormerVendor
Sounds good, what year is your truck?
Thanks, Ron
1-800-694-3098
Old Aug 16, 2010 | 07:33 PM
  #89
is there a true trac for the front diff? or does that not apply on the 60e 4WDs?
Old Aug 18, 2010 | 03:43 PM
  #90
FormerVendor
Hello, no, there is no Truetrac for the 8.25 IFS.
Thanks
