Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
Black Bear Performance Sells E-Fan Harnesses and Pulleys
Old 06-13-2009, 09:21 AM
supersub's Avatar
pm sent on the harness.
Old 06-17-2009, 09:05 PM
supersub's Avatar
Super fast shipping! awesome job on the wiring! thx!
Old 06-17-2009, 09:51 PM
Truck Sponsor
JennaBear's Avatar
Glad it got there before your trip!
Old 07-05-2009, 09:46 AM
11 Second Truck Club
bluecajun5.3's Avatar
anyone having problems with the pulley?
the machined thickness looks to be off from the stock one (105 amp alt pulley) and its squeaking like crazy.
also what is the sequence of the fans just so that i know they are working properly?
Old 07-05-2009, 11:00 AM
Hello Dave
dc_justin's Avatar
Did you get the nut tightened down fully? I could see it squeaking if it is a few ft-lbs shy of proper tightness.
Your fans should kick on via the following temps and A/C pressures.
{G0901} Fan #1 Turn-on Temp 201.031250 °F
{G0902} Fan #1 Turn-off Temp 194.984375 °F
{G0903} Fan #1 Turn-on By A/C Temp 198.007813 °F
{G0904} Fan #1 Turn-off Speed 35.000000 MPH
{G0905} Fan #1 Turn-on Speed 30.000000 MPH
{G0911} Fan #1 A/C Pressure Enable 209.960938 PSI
{G0912} Fan #1 A/C Pressure Disable 144.921875 PSI
{G0913} Fan #2 Turn-on Temp 216.007813 °F
{G0914} Fan #2 Turn-off Temp 202.015625 °F
{G0918} Fan #2 A/C Pressure Enable 280.078125 PSI
{G0919} Fan #2 A/C Pressure Disable 215.039063 PSI
{G0920} Fan#1 and #2 Both Off 40.000000 MPH
Old 07-05-2009, 11:02 AM
skeet's Avatar
i second this, thanks justin for the harness great workmanship also!!! thanks jenna for the help also!!!!!
Old 07-05-2009, 08:39 PM
thanks for the reply Justin.
not to be sarcastic or anything but i would think that a snap-on impact would be enough ft lbs on it. in the mean time, i put back the stock one on and it doesn't give me any problems.
Lance
Old 07-05-2009, 08:46 PM
Hello Dave
dc_justin's Avatar
Lance
Very strange. I haven't run into this issue before. I can toss another pulley onto my alternator sometime over the next couple of days to see if it squeaks. If all is well with that one, I can exchange it out for the one that you have. Sound good?
Justin
Old 07-05-2009, 08:50 PM
Justin
that would be great! also, i have removed it and placed it back on a couple of times to make sure it was properly seated.
Old 07-30-2009, 10:25 PM
shupe's Avatar
Justin / Jenna,
Know if the pulley will work on the GMT-900 altenators?
Matt
Quick Reply: Black Bear Performance Sells E-Fan Harnesses and Pulleys
