Belltech unleashes their 2014 GMFS Suspension
Belltech released their part numbers for the 2014 Silverado/Sierra 2WD this week. The NNNBS (2014) will use the same coil spring, spindle, front sway bar and rear shocks as the NNBS (07-13). Belltech did design a new flip kit. The new flip kit for this model truck corrects the axle position and vibration that you will experience issues with when using a NNBS (07-13) flip kit. Currently there is no lowering/lifting strut available for this model. It is due within the coming months.
Here is a photo of the Belltech 2014 Chevy Silverado w/ 22 wheels from the SEMA Show
(Photo Courtsey of Truckin Magazine)
Here are the part numbers for the various Lowering Kits & Components for the NNNBS (2014) trucks.
2014 Silverado/Sierra 1500 2WD Regular Cab Lowering Kits:
2"/ 3" Part# 984 Includes: 2 Spindles (2509) & 2 to 3 Shackles (6401)
2"/ 3" Part# 985 Includes: 1 to 2 Springs (12464) & 2 to 3 Shackles (6401)
2"/ 4" Part# 986 Includes: 2 Spindles (2509), 2 to 3 Shackles (6401) & 5 to 6 Flip Kit (6525)
2"/ 4" Part# 987 Includes: 1 to 2 Springs (12464),2 to 3 Shackles (6401) & 5 to 6 Flip Kit (6525)
4"/ 6" Part# 988 Includes: 1 to 2 Springs (12464), 2 Spindles (2511) & 5 to 6 Flip Kit (6525)
4"/ 7" Part# 989 Includes: 1 to 2 Springs (12464), 2 Spindles (2511) & 7 Flip Kit (6526)
2014 Silverado/Sierra 1500 2WD Extended/Crew Cab Lowering Kits:
2"/ 3" Part# 994 Includes: 1 to 2 Springs (12463) & 2 to 3 Shackles (6401)
2"/ 4" Part# 995 Includes: 1 to 2 Springs (12463),2 to 3 Shackles (6401) & 5 to 6 Flip Kit (6525)
4"/ 6" Part# 996 Includes: 1 to 2 Springs (12463), 2 Spindles (2511) & 5 to 6 Flip Kit (6525)
Spindles:
Part# 2511 *Designed to be use with min 3" or lower application *Min. wheel size 17".
Part# 2509 *Min. wheel size 17".
Coil Springs:
Part# 12464 1 to 2 for Regular Cab
Part# 12463 1 to 2 for Extended/Crew Cab
Shackles:
Part# 6700 1 Drop
Part# 6400 2 Drop
Part# 6401 2 to 3 Drop (*removes factory 1 block)
Flip Kits:
Part# 6525 5 to 6 drop
Part# 6526 7 drop
C-Notch:
Part# 6523 for Extended/Crew Cab (includes shock extender, bumpstops, bed crossmember ,template)
Part# 6524 for Regular Cab (includes shock extender, bumpstops, bed crossmember ,template)
Front End Alignment Kits:
Part# 4955 Front Camber Bushings 2 degree (4)
Part# 4951 Front end alignment cam lock plate kit 1 degree (8)
Part#4957 Front 2 degree Camber Bushings (4), Cam Lock Plates 1 degree (8) & Bushing install Tool
Anti Sway Bar:
Part# 5407 1 Ό Diameter Bar
Lowering Shocks (Rear Only):
0-1" Nitro Drop 2 Part#8536 Street Performance Part#2214FF
2-4" Nitro Drop 2 Part#8504 Street Performance Part#2212FF
5-7" Nitro Drop 2 Part#8510 Street Performance Part#2210FF
Spindles:
Coil Springs:
Shackles:
Part# 6700 1 Drop
Part# 6400 2 Drop
Flip Kits:
Part# 6526 7 drop
C-Notch:
Anti Sway Bar:
BCraven1018
Nov 2, 2015 07:18 AM
