B&M Trick Shift Fluid - 12 Quart Case
Available: December 1, 2016
B&M Trick Shift Fluid (12 Quart Case) - Part #80261
Description:
Trick Shift was originally developed by B&M for racing applications. It’s become so successful that it’s the most popular high performance fluid on the street also! Not an additive, this is the best performance ATF available! A scientific blend of foam inhibitors, pressure agents and shift modifiers that will provide extended transmission life and drastically improved shift feel. Trick Shift is the easiest way to measurably improve the transmission performance of your vehicle. Trick Shift works with all automatic transmissions when a firmer shift is desired. Pour in Performance is not just a catchy phrase - it’s reality! It can be mixed with stocktype transmission fluids, however to attain maximum improvement you should use Trick Shift exclusively. Ideal for towing, light trucks and RV applications as well as racing. Not recommended for electronic controlled transmissions. Case quantity of 12 qts.
Please call 707-544-4761 or visit www.bmracing.com for additional application and product information.
• Desirable Firmer Shift
• Ideal For Performance Street
• Ideal For Racing
• Not An Additive
Description:
• Ideal For Racing
• Not An Additive
