B&M Hi-Tek Deep Transmission Pan '01-'18 GM 2500/3500 w/ Allison Trans part# 71390
Application: 2001 to 2018 GM 2500 and 3500 trucks with the Allison transmission
Features: This B&M Hi-Tek Deep Trans Pan is designed for 2001 to 2018 GM 2500 and 3500 trucks with the Allison transmission. The pan adds 2.5 US quarts of additional fluid capacity for improved cooling efficiency over the stock transmission pan by using high quality cast aluminum. The Hi-Tek Allison pan also incorporates external cooling fins which not only look good but are also functional by increasing the surface area to help dissipate heat much quicker than the OEM stamped steel flat transmission pans. Additional features include Black MIL spec anodized finish, an engraved B&M logo, a magnetic drain plug for catching ferrous metals, a temperature sensor port, and mounting hardware. Gasket and filter not included.
• Engraved B&M Logo
• Additional 2.5 Quarts Fluid Capacity
• Magnetic Drain Plug for Easy Servicing
• Increased Cooling Effect
Questions? Looking for a product recommendation for your vehicle? Please give us a call at 707-544-4761 or visit BMRacing.com for additional application and product information.
B&M Racing
04-26-2018 02:01 PM
B&M Racing
04-26-2018 12:51 PM
B&M Racing
04-26-2018 12:35 PM
