Yanking the 5.3L with a vengance
#54
Racetronix makes plug and play extension harnesses for the knock and cam sensors. you can use LS1 knock sensors but they look like *** sticking 3in out the side of the block. but i cant use LS2 sensors since there Full digital 2 wire vs 1 wire. i am gonna search for GTO knock sensors since thats an LS1 PCM. as for the cam sensor you have to use a corvette ls2 cam gear and front cover with the cam sensor built in. the reluctor wheel is the tricky one. the GTO is the only car i know of that comes with a 24x reluctor wheel in an LS2 which as you know is critical to the proper operation of the PCM. s unless you find a GTO LS2 you have to swap reluctor wheels which requires complete engine tear down. other than that it's a direct bolt in lol
#55
Aren't the LS1 GTO knock sensors the same as the truck knock sensors? They still go in the valley cover AFAIK.
#56
and yes the GTO LS1 GTO sensors are the same but they are still in the valley whereas the LS2's are on the side of the block.
#58
