Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
When is the next H town GTG??????
Old May 3, 2007 | 10:09 PM
  #31
Wheatley's Avatar
Truck Sponsor
ok,no they will not be open on Friday night.,I just checked.
Old May 3, 2007 | 10:33 PM
  #32
good deal charlie, so what does everyone want to do? probably will be later in June before there isnt an event on Saturday.
Old May 3, 2007 | 10:39 PM
  #33
ZZebes's Avatar
Originally Posted by Tootall
a trans already? . . . . don't you already have a new truck, or was that someone else's truck that you showed up in?
Well that was my truck but it has eaten 3 trans in 30,000 mi and i am getting a 3200 stall converter and a cam and headers soon after so i decided to order a level 4 from FLT as a precautionary measure so i don't turn my 4l60e into a hand grenade.
BTW your truck sounds badass. i heard it coming.
Old May 4, 2007 | 12:12 AM
  #34
TXsilverado's Avatar
is that all of your performance mods in your sig? if so you need to either kill your tranny builder or choke the guy who tuned your truck. if thats all the performance you got you shouldnt be able to go through 3 in 30k miles
ill have the cam in and tuned so you know ill try like hell to make it out
Old May 4, 2007 | 08:30 AM
  #35
Tootall's Avatar
hey thanks! I've got a shift kit, and that's it, no stall on mine, and I just rolled over to 110K
Old May 4, 2007 | 09:09 AM
  #36
Colby 04's Avatar
Stewart, did you get your gears replaced?
Old May 4, 2007 | 10:11 AM
  #37
ZZebes's Avatar
Well sadly it's eaten trannys snce day one. my first one went at 1,500 miles and the second one went at 10,000 i got my dyno tune at around 20,000 miles and this one has died a slow death. but i am what i guess you would call a "Spirited" driver. I am actually starting to wear a hole in the carpet where my gas pedal is rubbing the floor.
Old May 4, 2007 | 03:16 PM
  #38
you just have horrible luck the. im what they call an abusive driver abusive driver with alot more power and ive only cooked 1 transmission. then again ive have pretty good luck...colby i fixed the gears that were in there already. just tightened the pinion nut back down and put new fluid in there
Old May 4, 2007 | 03:59 PM
  #39
Colby 04's Avatar
tick...tick....tick......tick........
Old May 4, 2007 | 04:02 PM
  #40
ZZebes's Avatar
well the first one was a really pissed off little bro who threw it into park at 80 on the freeway. that sucked
