ready to sell my tick tick tick machine
#43
Truck addict
well, when i get time i am going to pull the motor out and check everything. i have a extra set of head gaskets. but yes i will check the O ring.
#45
Sexy Party Mod
It does sound like the o ring. Drop the pan off the bitch and change the oring. I dropped the cross member, unbolted the steering and pushed it out of the way. Worked like a charm.
#47
why pull the motor? You're friggin' crazy - listen to these people. That o-ring won't take but an hour to get to and check. Both Cody and Beau had o-ring issues, they know what they're talking about.
#48
O friggin ring!!!same symptoms I had
TSB
Engine - Knocking or Lifter Noise
Notes
File In Section: 06 - Engine/Propulsion System
Bulletin No.: 02-06-01-038
Date: December, 2002
TECHNICAL
Subject:
Engine Knock or Lifter Noise (Replace 0-Ring)
Models:
2001-2002 Chevrolet Camaro
2001-2003 Chevrolet Corvette
2001-2002 Pontiac Firebird
2002-2003 Cadillac Escalade, Escalade EXT
2000-2003 Chevrolet Suburban, Tahoe
2001-2003 Chevrolet Silverado
2002-2003 Chevrolet Avalanche
2000-2003 GMC Yukon, Yukon XL
2001-2003 GMC Sierra
with 4.8L, 5.3L, 5.7L or 6.0L V8 Engine (VINs V, T, Z, G, S, N, U - RPOs LR4, LM7, L59, LS1, LS6, LQ9, LQ4)
Condition
Some customers may comment on an engine tick noise. The distinguishing characteristic of this condition is that it likely will have been present since new, and is typically noticed within the first 161-322 km (100-200 mi). The noise may often be diagnosed as a collapsed lifter. Additionally, the noise may be present at cold start and appear to diminish and then return as the engine warms to operating temperature. This noise is different from other noises that may begin to occur at 3219-4828 km (2000-3000 mi).
Cause
The 0-ring seal between the oil pump screen and the oil pump may be cut, causing aeration of the oil.
Correction
Inspect the 0-ring seal and replace as necessary. Use the applicable part number listed below. Refer to the Engine Mechanical sub-section of the appropriate Service Manual.
#49
Truck addict
i'm going to replace the O ring. thats a given. i really appreciate yalls help. i'm not trying be stubborn at all. i'm going through as much as i can to help ensure other areas were done properly
