Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
problem with my beater
Old Mar 2, 2008 | 02:47 PM
dry_kill's Avatar
Default problem with my beater
well i just got brand new tires, balanced, just had the inner and outer tie rods replace, got an alignment done and im still getting a bad vibration when i hit the brakes, what else could be the problem fellas? its a 93 honda accord. thanks
Old Mar 2, 2008 | 03:14 PM
bigbadwolf54's Avatar
13 Second Truck Club
warped rotors?? if its only vibrating when you hit the brakes Id look there
Old Mar 2, 2008 | 03:30 PM
skeet's Avatar
yep have the rotors checked, went through the same problem on a malibu maxx also had a warped rim or actually bent rim
Old Mar 2, 2008 | 04:41 PM
00Silv4.8's Avatar
unless the tire place is mentally challenged and didnt see any bent rims and note it its ur rotors
Old Mar 3, 2008 | 07:26 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
rotors are cheap at autozone. believe it or not, that work well & last long (as long as you don't let the brake pads jack 'em up).
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
