Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
need a little help here.
Old Nov 28, 2007 | 06:25 AM
ThunderZ28's Avatar
12 Second Club
Default need a little help here.
anybody ever come accross this code?
P1345 - Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
My wifes 99 (OBS) Yukon is showing this ..
she complanes about it not wanting to start, and being slow to start, but everytime I go out to look at it, it starts fine for me..
I never drive the Yukon, so I dont know the quirks with it..
She tries her hardest to explain what is going on, but she gets mad at me when i start chuckling at how she describes what it is doing...
any ideas?
just thought I would shoot this in here.. to see if I could get an answer..
Thanks
Daniel
Old Nov 28, 2007 | 07:16 AM
Grumpy5.3's Avatar
your dist moved most likely. You need to set the CMP retard. It can be between -2 and +2, 0 is optimal. you have got to rev the engine over 1k rpms to see change after you move it. USUALLY if you loosen the dist, turn it as far as you can counter clockwise with the wires hooked up, tighten it back up and rev it up, its usually right.
Old Nov 28, 2007 | 07:18 AM
ThunderZ28's Avatar
12 Second Club
all right thanks..
I'll check it out tonight when the wife gets back home
Chewy07
Nov 14, 2015 09:46 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
97_ek
Sep 23, 2015 09:16 PM
whitelazer
Sep 22, 2015 09:38 PM
Chaney3000
Sep 11, 2015 01:37 PM
