Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
I need a schematic
Old Oct 22, 2007 | 08:06 AM
silver-mod-o's Avatar
Hunt&Fisherator
Default I need a schematic
For a fan harness... I dont want to go out and buy one, I'd like to build my own and put my trans fan in the circut with it with its own temp switch. I know a few people have built their own, I need some direction. If nobody can figure out a way to do it and put the trans in it as well, I'll do that seperately... I can believe I'm still running aruond with a clutch fan, I've had these fans sitting in my closet for a while now.
I can get the GM fan plug ends from a junkyard for nothing probably and I have access to a ton of wire and connectors and loom etc etc... all I think I may need is a couple relays... please help if you can.
Old Oct 22, 2007 | 09:30 AM
Tootall's Avatar
you must not have used the search
and here's the ignition controlled "hot" in the cab.
Old Oct 22, 2007 | 09:53 AM
Hunt&Fisherator
thanks for the help.
Old Oct 22, 2007 | 12:35 PM
nonnieselman's Avatar
ive used that setup on several of my buddies truck including mine and works great!!!!
Old Oct 23, 2007 | 03:03 PM
white1's Avatar
When I was building them, I never worried about the ignition controlled hot. Just ran it to a constant hot (or did I run them both to an ignition controlled hot???? hmmmm) Ask derek@EDH (or whatever it is lol)
lxcoupe
Aug 22, 2015 08:23 AM
TrickyTransAm
Feb 3, 2011 05:10 PM
MHSLOT12
Aug 11, 2008 07:29 PM
kirtondog23
Jun 20, 2007 10:30 PM
013
Feb 20, 2007 09:41 PM
