check this out
Yes, I will send them to you next week, the computer is at Fastchip. They are reprogramming it, I hope we found a little more h/p & torque. The trans is 65 with kevlar belts and steel clutches. GM did the work and states it will hold better then a 80. We have had no problem with 2nd gear on a hard pull. I will forward you a list on the motor as well, the gear is 410, the heads are AFR, i will find the paperwork. I'm a little behind on scanning the list. Thanks
Oh and LMAO @ a mail order 1000hp tune
The cam is 232/240 the lift is 574/589, Comp rockers 1.7, AFR Mongoose heads, compression is 9.1, injestors are 60lbs, the boost is 12lbs, the rear gear is 456, the stall converter is 2500. Hope this answers your questions.
Hmmmmm
Originally Posted by nightrunner
sorry but a 408( of any kind) with 12lbs of boost and 60lb. injectors is gonna come up a bit shy of 1000hp
GMCtrk
18
Oct 6, 2015 03:48 PM
Closer_2001
Sep 24, 2015 09:15 PM
nice one!
smiley on him...guess his own auction wouldn't be the best place to do that huh?
