Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
4wd launch help
Old Sep 11, 2007 | 06:06 AM
02 z71 silverado's Avatar
Originally Posted by $thatguy$
i know how to solve that........................... don't do it
haha his wheels are bowed in anyway just sitting still cause his front is lifted so high.
Old Sep 11, 2007 | 10:25 AM
DixieDevil's Avatar
+1
Old Sep 11, 2007 | 12:38 PM
slowprocess's Avatar
Is that truck really blowing the tires off enough in 2wd to actually need to launch in 4? I'd just feather it out alittle bit until I bought a set of drag radials for the back.
Old Sep 11, 2007 | 12:53 PM
sharpshooter's Avatar
This happened to my friends lifted DMAX[about 500 hp and 1000 ft lbs. of torque at the wheels and 6" lift with 35"/13.50" tires] and all other DMAX diesels I know that boost launch in 4wd.It is actually the stock tie rods and center link on the steering bending under all the power.My friend put Cognito's tie rod ends and support brackets on his.It launchs totally straight now.There are cheaper fixes such as, Fabtech's tie rod sleeves.
Old Sep 11, 2007 | 12:56 PM
You can go to dieselplace.com and do a search on tie rods and you'll find all kinds of info. on this.
Old Sep 11, 2007 | 01:19 PM
explorer5.0's Avatar
TOTM: November '07
A truck that has the torsion bars cranked up as high as you do has almost no downtravel on the front suspension. This makes for a really harsh weight transfer onto rear making the truck bounce front to rear. Because you have no downtravel in the front, when that weight does transfer to the rear, you front end goes severly positive camber-this is why it looks like you are riding on the outside edge of your tires.
Old Sep 11, 2007 | 02:51 PM
07 z71 silverado's Avatar
11 Second Club
i got a leveling kit i dont know if the torsion bars are turned at all.
Old Sep 11, 2007 | 03:55 PM
im pretty sure they are turned.
Old Sep 11, 2007 | 04:42 PM
11 Second Club
you dont even know where they are
Old Sep 11, 2007 | 04:50 PM
Yes i do. Thats like the easiest thing. how do you think i know mine are turned?
