Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Head\Cam swap
Old Sep 13, 2010 | 08:15 AM
  #51
bonj87's Avatar
OK its done.. in a way
parts are on truck runs.. we have some issues to work out with idle and misfires.. but. ..
First.. I cannot thank ShadowSniper and Oleshifty enough for thier help!
Without them, this project not only would have stalled months ago, but would NEVER have come to fruition!!
I also must give MAJOR thanks to Zippy for answering his phone on a Sunday and providing us with some unknown knowledge that saved us!!!
Start up video is here..
http://s586.photobucket.com/albums/s...t=MVI_0606.mp4
Old Sep 13, 2010 | 02:13 PM
  #52
bonj87's Avatar
anyone have any guesses or ideas why the truck will run fine up to about 3800 RPM and then start missing like crazy after that?
Old Sep 13, 2010 | 10:38 PM
  #53
bonj87's Avatar
http://www.youtube.com/watch?v=1kk3COaWruU
theres the video.. ideas thoughts?
i say tune..
Old Sep 15, 2010 | 11:12 AM
  #54
OnyxSilveradoSS's Avatar
i say tune..
can you log or look at the tune? without doing that I dont think 'its the tune' is your best guess...
I would double check stuff first, Then try to get the truck scanned and logged when it misses, should have some codes??
things I would check:
rockers, if one is lose/not seated it might show up at the higher RPM's
Fuel pressure
good luck...keep us posted.
Old Sep 15, 2010 | 11:17 AM
  #55
bonj87's Avatar
The rockers were torqued properly not once, but twice.. they SHOULD be ok.
at this point i still suspect either the tune, or one of the injectors is dirty.
we checked for vacum and intake leaks and found none there.
its throwing lean codes for banks 1 and 2.
Old Sep 15, 2010 | 12:25 PM
  #56
both banks lean would rule out a single injector.
What are you running for fuel spstem?
Maybe a bad pump. bad regulator. broken pick up
Old Sep 15, 2010 | 12:51 PM
  #57
bonj87's Avatar
new injectors (well used, but upgraded to 42 lb ones)
stock fuel pump, stock regulator fuel pressure looks good. the same as it was before the swap
Old Sep 15, 2010 | 01:10 PM
  #58
you are sending zippy your PCM to tune or do you swap them with a core PCM??
A log and scan are gonna be needed to find out more, timing/KR/Injector stuff
And Brad knows his stuff! His truck is smoking!
Old Sep 15, 2010 | 01:12 PM
  #59
bonj87's Avatar
im going to order a wideband today so i can log that, and i tried to log it with some other software.
zippy did not tune me, nelson did and they lock the tune..
however.. ZIPPY.. if yer ever in my neck of the woods.. let me know..
Old Sep 15, 2010 | 01:35 PM
  #60
Locked tune I would call them. They have to unlock it...You can also find a core PCm and send it to zippy and like majic it comes back in the mail...I logged my mail tune with a wideband and tuners and I was surprized how good Zippy's tune was thru the mail.
There are alot of calibrations so maybe Nelson just forgot one or did not remember all the mods he was tunign for, give him a chance to get you right.
