Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Chasis dynoing a AWD SS
Old Dec 19, 2005 | 01:09 PM
maddboost's Avatar
Default Chasis dynoing a AWD SS
Is there any problem with disconnecting the front driveshaft on a AWD SS to dyno tune it on a 2WD chassis dyno? Obviously there is a slight load difference but most tuners can compensate for this.
Old Dec 19, 2005 | 01:27 PM
ZR1 DREAMING's Avatar
I couldn't quote the parts, but I've heard it puts tremendous stress on something. I'll see if I can find the thread over at SilveradoSS.com
Old Dec 19, 2005 | 01:50 PM
Try and find a shop that will do AWD dyno's it will have to be an import shop but they can normally get that done for ya.
Old Dec 19, 2005 | 02:08 PM
maddboost's Avatar
My problem I only have one tuner I trust and they have a 2WD dyno. The only AWD dyno in the area is over an hour away from my tuner and im not even sure if my truck will fit on it since its designed for tuning AWD Mitsubishis.
Old Dec 19, 2005 | 02:56 PM
Blow03SS's Avatar
The only problem with the import dyno tuners are the wheel base they can support. I have had my truck on the dyno with the half shafts removed and had no problems, and that was throwing down 472HP. Most of the SS owners that I know do it this way. You should have no worries about pulling them for a dyno run, just no driving arounnd on it like that. You will smoke that x-fer case in a hurry.
Old Dec 19, 2005 | 06:23 PM
mattrem's Avatar
I pulled the front driveshaft on my dyno tune, There is no problem in doing it. Bryan Herter has done it several times without any problems. I certainly wouldn't drive it around without it, it will kill the transfer case.
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Lthompson
Oct 2, 2015 12:45 AM
StrokeTheLS
Sep 29, 2015 08:33 PM
