Got the coilover kit from atomic and decided to put the Viking double adjustables on the rear as well. On the lower mounts, the shock body slightly contacts the mount, pic below.
Safe to run them like this, or do I need to modify the mount?
Do like i did and add some washers to the bolts on the bracket to the rearend. That will spread the lower shock mount apart as well. Thin shim with more washers for the shocks.
Edit nevermind i thoughy u was using relocated shock mounts. Take a large adjustable wrench and pull the brackets apart some.
