Z06 calipers on 15"rotors on a SSS
#78
Now with the rear brake setup. That is the fitted with the Z06 calipers and 14'' rotors as well? I take the rearend is a 14-bolt. What kind of brackets did you use to mount the calipers to the 14-bolt axle housings?
#79
#80
Yes and No. I used the rear calipers from the Z06,they are the 4-piston,added a rear 14" rotor that matched the front 15" rotors, and installed them to the factory mounts on my current 10-bolt axle,other than cutting some of the dust shield out of the way, after that they were a direct bolt on using a special bracket.
