Will this affect acceleration?
Old Nov 3, 2005 | 11:19 PM
BlackLM7's Avatar
Default Will this affect acceleration?
I currently have the stock 16" chrome steel wheels with 255/70-16 General tires. Together, they weight approx. 64 lbs. I plan on getting 18" Torq Thrust ST wheels with 285/50-18 tires. According to TireRack.com, this combination will weigh approx. 68 lbs. Also, the tires I want are 1 inch shorter in diameter and 1 inch wider compared to my stock tires. So, considering all these measurements, will my truck's acceleration be the same, faster, or slower. Obviously, the additional 4 lbs. and going from a 16" wheel to a 18" wheel will slow down a vehicle but will the shorter diameter of the new tire compensate for this?
Old Nov 3, 2005 | 11:45 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Probably about the same. Im getting the same wheels but toyo proxe s/t 275/55's and I think it will be better for me since I have 32" all terrains on my truck right now.
Old Nov 4, 2005 | 02:17 PM
Gran Patron's Avatar
I was thinking it shouldn't affect any accelaration and should remain about the same as mentioned above!
Old Nov 4, 2005 | 05:35 PM
niwtsol's Avatar
no u are goin to have slower acceleration with the 18's. its not so much the weight but where the weight is located, with an 18 inch tire u are puttin the weight furhter from the axle of roation which increases the roational inertia of the tires, the smaller diameter will help it a little but overal u are gion to be acceleration slower, i dont kno how much slower though.
Infernohoe
48
Oct 2, 2015 10:25 PM
Tigger Welder
Oct 1, 2015 08:41 AM
Chevy305
Sep 28, 2015 09:21 PM
01silvy
Sep 26, 2015 10:20 PM
Lthompson
Sep 15, 2015 07:55 PM
