Who's powdercoated their wheels?
#52
i got replacement ones directly from centerline for like 20 shipped several years ago so i would say prob 25 now. i was gonna try to rig up some and then told myself them replacement caps are expensive i rather not risk riggin some up and elected to buy actual centerline replacements.
#53
Black lug nuts?
Alright guys, what do you think?
These?
24 NEW BLACK ACORN LUG NUTS M14X1.5 14X1.5 DP5308SPBK | eBay
Or these?
24 BLACK CLOSED BULGE ACORN WHEEL/LUG NUTS 3/4" D3148P | eBay
Here's the really weird thing. Both eBay links are from the same seller. Only, one is cheaper than the other.
Is there something I'm missing?
I want black lug nuts. Are these good? Or does anyone have any better recommendations?
Thanks fellas!
These?
Or these?
Thanks fellas!
#54
Okay first off, here's a pic of the first half of my driveway. That's why my truck is always dirty in the winter. I just gave up. That, and the trees drop leaves and needles on it all the freekin time.
On to the bad news. I finally got some replacement o-rings. I also ordered some black lug nuts from Summit. Yesterday was my day off so I was going to do the whole tire and wheel switch-a-roo. All I had to do was get the center caps installed.
I pressed on them pretty hard and of course it was a tight fit. They wouldn't go in so I sprayed some lubricant on the o-ring. Then I kept pressure on the center cap and gently pressed on the exposed (pinched) o-ring. It worked pretty well.
Then all of a sudden the center cap snapped into place and this happened.
Ugh. I didn't hit it with a hammer or anything. I guess when it finally seated the force chipped off the powder.
So I emailed the guy that powder coated the wheels. He told me to drop them off and he would take a look. I guess he could just sand blast a small area and recoat it right?
Next time around I think I'll use some silicone caulk instead of o-rings. What do you guys think?
#55
Slowest turbo build ever!
The guys at Centerline told me the o-rings are made specificaly for them to withstand high heat, that and the orings ARE what hold the centercaps in place inside the wheel. They also told me just to use some soapy water on the o-rings to put them on. I had no issues with doing it that way when putting my centercaps on after having them balanced.
#56
Thats some shitty *** powder coat imo, i had a tough time getting my caps on and put some oil on them and did the same as what you are describing on mine with no problems.
To give you an idea how tough the powder coat was on mine, i wrecked the truck by clipping a telephone pole, the wheel lip of my centerline got bent close to 90* and the coating didnt even chip or come off at all, just stayed coated to the wheel..
Even without the chipping happening, you can just tell by the pic its not the greatest quality coating..
