What type of tape to use for badges?
Old Jan 18, 2008 | 04:10 PM
thunder550's Avatar
High on diesel fumes
Default What type of tape to use for badges?
What should I use for sticking a used badge on that doesn't have the factory tape anymore?
Old Jan 18, 2008 | 04:14 PM
Mangled03gmc's Avatar
Baltimore Whore
D U C T Tape.
Old Jan 18, 2008 | 04:15 PM
kbracing96's Avatar
The gray double sided stuff
Old Jan 18, 2008 | 04:21 PM
thunder550's Avatar
D U C T Tape.
Done! Looks good eh?
I'm worried about it taking the paint off with it if I ever decide to pull the badge off. You think I'll be ok?
Old Jan 18, 2008 | 04:25 PM
explorer5.0's Avatar
TOTM: November '07
I used the white double sided foam tape before. As long as the surfaces are clean, it will last a long time. It will dry rot after a few years though.
Old Jan 18, 2008 | 04:27 PM
beastmode's Avatar
Import Moderator
i think this is the P/N for it brand new (#15153105) but check with Shannon... says
GM PART # 15153105
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
OUR PRICE: $22.97
for that price i wouldnt even screw around wit taping and stuff... should have new tape on it already, you figure any tape your probably gonna but is atleast $5
kbracing96's Avatar
If they did a shitty job putting the paint on, it might, but you should be fine. That's what most cheap body kits and aftermarket badges that I've see are put on with
Old Jan 18, 2008 | 04:28 PM
thunder550's Avatar
GM PART # 15153105
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
OUR PRICE: $22.97
I'm not doing a new Chevrolet badge...I'm getting a 6.7L badge off of a buddy's GTO. It was pieced together out of a 6.0 and a 5.7 badge, so I can't exactly buy a new one unfortunately.
Old Jan 18, 2008 | 04:29 PM
thunder550's Avatar
Hey don't doubt the power of the gray 3M tape....it pulled the drywall off when I removed the alarm clock that I had stuck to the wall in my old dorm room
Old Jan 18, 2008 | 04:36 PM
kbracing96's Avatar
Ya, but that's just paper, not paint A little adhesive remover on top of it left to soak a few minutes and I but it would peel right off. Dought its any stronger then the factory stuff
