URGENT wheel help needed
Old Jun 25, 2008 | 08:44 PM
Comet 64's Avatar
Default URGENT wheel help needed
Hi,
This is my first post but I need some wheel help. I have an 02 Silverado and I found some American Racing RT-S wheels for cheap. The problem is that they are 6 x 115mm wheel pattern. My question is, can you safely use wheel adapters to get the 6 x 5.5" pattern? I found some adapters on-line to make the conversion. Also, the wheels have a 35mm offset if that matters.
Can I make this work?
Thanks
Old Jun 25, 2008 | 09:19 PM
00Silv4.8's Avatar
Can it work: Yes
Should u do it: NO
for starters u need to find wheels with deeper offesets to prevent them from sticking out (usually contacting the fender). They're generally considered unsafe as well because they sit out farther than where the wheel is set up for. Its ur call, it is possible to work tho
Old Jun 25, 2008 | 09:32 PM
fastnblu's Avatar
IDK if it'll work, but I agree w/ prevoius on how safe they are; spacers aren't track legal either.
Old Jun 25, 2008 | 09:53 PM
Comet 64's Avatar
That's what I was afraid of. It's a great deal but if it's unsafe, I'll have to pass and keep on looking.
What offset should be used? 18mm?
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
Sbrown06
Jul 9, 2015 09:21 AM
