Suspension Question, will this work?
Old Sep 24, 2003 | 04:53 PM
abbo7's Avatar
Default Suspension Question, will this work?
One of my friends with a Lightning says that by using 2 inch drop shackles and removing one leaf from the factory leaf springs it will drop the rear of a Lightning 4 inches and in turn help it get better traction. He said that there are a lot of people doing this on L's. I was wondering if us Silverado guys can do this as well? If so that would be a great alternative to buying leafs for the rear, because you would only spend $ on shackles and 2 inch lowering springs for the front to get that 2/4 drop.
Old Sep 24, 2003 | 04:55 PM
Ling_650vette's Avatar
Default Re: Suspension Question, will this work?
I dunno about the drop height, but it may help with traction. Leaf springs dont help all that much w/ traction. Ive heard of more stories of ppl getting better traction by goin 4-links w/ coilovers. But, pulling out a leaf will definatly drop it a bit, but it may not be as beneficial in the traction end
Old Sep 24, 2003 | 06:04 PM
sleepersilverado's Avatar
ok he is not lying. generaly you get an inch from removing a spring. but it varries on the app. i would not do it on our trucks because there are not enough springs. therefore i believe it would bottom out very easy because it is going to be so soft. you could maybe do it with a set of helper bags. the only way i could see it benifiting traction is it would help with weight transfer.
Old Sep 24, 2003 | 07:55 PM
1HOT99SILVERALDO's Avatar
No It will not work on ours.I tried that and like sleeper said not enough springs.As soon as I took a leaf out and let the jack down the frame was on the axle.
Mike
www.geocities.com/mikestruckshop2003/1HOT99SILVERADO
Old Sep 25, 2003 | 10:35 AM
BigKID's Avatar
But you can clamp down the overload leaf. This will drop it about an inch and also help with axle wrap/wheel hop. We've done it on two of my friends trucks and it works.
Old Sep 26, 2003 | 05:50 AM
Yeah sounds good, I have seen some of the fastest older cars at the track with leaf springs, running a single leaf with a traction bar. Seen a bunch of Caltrac owners out there, funny I never even heard of them until this website.
Old Sep 26, 2003 | 07:47 AM
If you want performance based leafs, i've heard Hotchkis has some kickass components
Old Sep 26, 2003 | 09:56 AM
BigKID's Avatar
Yes they are. But that throws the cheap factor out the window.
Old Sep 26, 2003 | 03:05 PM
I have done this on my 91 and also on my 03
On the bottom of the spring pack is a loose helper
it is not clamped in with the rest of the pack of leafs
If you remove all four nuts on the u bolts - jack the rear end up - remove the locating pin and nut - you can remove that bottom leaf - reassy
It will lower the truck a little- maybe .5 to 1 inch max
It will also reduce your load carrying capacity - if you
care about that - But it does work
Traction ?? Dunno - maybe a guy that races harder than I do can chime in.
Old Sep 27, 2003 | 10:19 AM
GREGGO's Avatar
Can you shoot me a pic of exactly what you did here?
