SS Question...
Originally Posted by 05_GMC_SLT
Originally Posted by SSCrew_Cab
Will it fit a crew cab?? the bed is shorter...
I've got a set of the cladding for my truck. I was EXTREMELY lucky when I bought mine. I paid $500 shipped for all the cladding and then another $200 for all the brackets. Now that $500 was just the cladding and didn't include the front or rear bumpers. There may be other deals out there like this, but it took me a year of searching in order to find it. I've had people contact me trying to buy the stuff off of me before and they offered me as much as 3X what I paid for everything.
If your truck is a crew cab, your going spend a lot of $$$ modifying the pieces to fit your truck. The under door rocker piece will have to be stretched along with the rear door pieces and the cab corners will have to be modiifed as well. Plus, I believe the bed on crew cabs are shorter than a reg. silverado so the bed pieces will have to be modified as well. Being that it's costing me $500 just to have my 2 cab corners modified, I'd say you'd be lucky if you did it all including paint for less than $4,500.00 and that is buying the pieces used. I have a list of all the part number needed if your interested.
Here are some numbers I just copied from the silverado ss website. These are just the cladding pieces. Also, just an FYI, you can not buy the cladding brackets individually, you can only get them with the cladding piece. I have a list of those part numbers at my house. I'll try to get them scanned in and loaded up later tonight or tomorrow. Again, these numbers are for just the cladding pieces, and it does not include the brackets. if you want the cladding with the brackets, you need the part numbers that I will load later tonight. I hope this helps
15197889 - License Plate Bracket
15178219 - Crossbar and Grille
12335659 - Front Bumper
12335765 - Front Bumper Grille
12335766 - Passenger Air Duct
12335767 - Driver Air Duct
10360423 - Driver Front Door Molding
10360428 - Passenger Front Door Molding
10360434 - Driver Rear Door Molding
10360441 - Passenger Rear Door Molding
15178226 - Passenger Fender Molding (Behind Front Wheel)
15178227 - Driver Fender Molding (Behind Front Wheel)
88980000 - Passenger Rocker Panel (Under Door Cladding)
88980186 - Driver Rocker Panel (Under Door Cladding)
15178234 - Passenger Rear Fender Molding (Before Rear Wheel)
15178235 - Driver Rear Fender Molding (After Rear Door)
15197858 - Passenger Rear Panel (After Rear Door)
15197857 - Driver Rear Panel (Before Rear Wheel)
88944467 - (Not sure which side) Silverado SS Panel (Behind Rear Wheel)
88980189 - (Not sure which side) Silverado SS Panel (Behind Rear Wheel)
15178282 - Lower Tailgate Molding
Yeah, I know its going to be expensive, but that's what I really want. I was thinking that I was going to have to get 2 sets of doors, and have one set customized for the back doors. I'd really appreciate it if you gave me the parts numbers...thanks.
