Smoked Tail Lights
Old Dec 10, 2006 | 10:31 AM
SmokedSierra01's Avatar
Default Smoked Tail Lights
Does anybody have any how-to directions on smoking the rear tail lights?
Old Dec 10, 2006 | 11:17 AM
Derek @ EDO's Avatar
FormerVendor
its very easy
buy some VHT Niteshades, its a spray in a can.
Take off taillight, get some 500 grit wet sand paper
put some water on the sand paper then scuff up the lens, this insures the spray to adhere.
dry lens with rag
put a light coat on, let dry
then put more coats on until you are satisfied with the "shade" of the lens. Just be sure to let each coat dry before applying another.
then do the same to the other.
Old Dec 10, 2006 | 11:35 AM
Thanks a lot. Is this legal or am I gonna get harrased when I do this to the lights?
Old Dec 10, 2006 | 12:07 PM
TouchOfEvil04's Avatar
Depends how dark you go. If you can clearly see the lights during the day when pressed then you will be fine. I have mine done with two coats on em and i can still see the light just fine.
Old Dec 11, 2006 | 05:20 AM
COLDZ71's Avatar
How to candy taillights.--GMFullsize.com You can use the directions here. Just use VHT Nightshades instead of the Testors red.
RustyD
May 23, 2016 07:04 PM
Texas5.3_1251
Mar 5, 2016 08:10 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
carid
Oct 1, 2015 09:22 AM
Closer_2001
Sep 16, 2015 11:46 AM
