Smoked me 3rd(cab) light... :D
#21
Heres mine, but i incorporated a bowtie in the reverse part of the tail.
I also used non "rattle can" clear, mixed with black base coat in a gun shot that, then just plain clear one or 2 coats.The only reason i just " real clear" i had some left over from clearing another car, Otherwise what John did will work fine.
#26
#27
Yes the more you add the darker it gets.. That is with ruffly 2 coats.. People say to spray it even, but it doesn't really start flowing out untill it is down for a little bit.. So about 5-15 min, depending on the temps.. As for the buffing, a final 1500 wet sand, a foam pad with ultra finishing cut works great.. Just have to be easy as this clear is hard, it is not quit as hard as a good automotive clear..
#28
I did about 4 coats on the headlights which looks dark, but after you sand some material will come off and lighten back up. I think I am actually gonna sand my again and shoot another coat or two of vht too darken up a little more..
#30
these are my rear reflectors on my tbss, 3 coats, same process.
http://i1146.photobucket.com/albums/...3/IMAG0502.jpg
