Shoulda came stock on the truck
Old Feb 1, 2005 | 07:42 PM
  #21
chris99gmc's Avatar
Originally Posted by 2toneblown
Whoa Whoa Whoa, that looks sick how did you do that exactly?
I pulled the cluster. Took off the bezel. Masked off the rest of the gauges and pulled the needles so I wouldn't get steel shavings stuck in between anything(there was alot of steel shavings since the overlay is Real stainless)...
I took the actualy boost gauge apart from it's own bezel, and then traced the outline of it and started the cutting the bezel from the center of the hole outwards. I made sure NOT to cut too much and then gradually got the hole closer and closer to size until i could shove it in there really snug, so it won't move.
I then checked the rear of the gauge for clearance and ran the line to it... made sure everything was straight and that the gauge was flush with my overlay and then re-installed the escalade bezel over it.
.... not too tough of a project. Maybe a 4.5 out of 10. The hard part is just cutting a hole through the expensive cluster and aftermarket overlay.
-and you guys got it right, it's a 99-02 Escalade bezel over the stock cluster with the US speedo stainless steel overlay.
Old Feb 1, 2005 | 09:08 PM
  #22
badpewter-z's Avatar
LS1TECH Sponsor
looks killer
definetly like it belongs
Old Feb 1, 2005 | 09:10 PM
  #23
Ryan23silverado's Avatar
Originally Posted by snakeoiler
That is the snizzle, fo shizzle!
(Did I use that correctly? )
I think it's "That is the shizzle, fo' rizzle! j/k
Those gauges do look killer! So that is an Autometer stainless face boost gauge?
wrb002
Aug 31, 2015 12:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
gavin2005
Jul 16, 2015 12:09 AM
4B11T
Jul 13, 2015 03:48 PM
