should i change drag wheels?
Old Aug 3, 2007 | 08:48 AM
beastmode's Avatar
Import Moderator
Default should i change drag wheels?
Goin to the track tonight adn i wann do what i can
Currently i have AR767 steel wheels for my ET streets
i also have a set of AR672 i think both wheels are the same size but it seems that my aluminum ones were pretty light... would i gain anything from swappin to the aluminum ones and ditchin the steelies?
AR767 Steel
AR672 Polished Aluminum
Old Aug 3, 2007 | 10:01 AM
Phantom's Avatar
11 Second Club
every little bit helps
Old Aug 3, 2007 | 10:19 AM
beastmode's Avatar
Import Moderator
i also have a set of stock steelies, wonder if these would be any less?
Old Aug 3, 2007 | 10:25 AM
Phantom's Avatar
11 Second Club
my stock steelies weight 200lbs less than my 20's...
Old Aug 3, 2007 | 10:34 AM
beastmode's Avatar
Import Moderator
Holy ****!!! thats ridiculous, you ever run wit the 20s? that probably saves you like .2-.3 for the 1/4
i think i am gonna swap to the Aluminum ones or the stock steelies, the ETs and wheels are so fuggin heavy right now, im sure puttin these aluminum ones on will make a lil diff
Old Aug 3, 2007 | 10:46 AM
BlackGMC's Avatar
Resident Retard
what about picking up some stock aluminium wheels and runnin those, it probably would be cheaper...
Old Aug 3, 2007 | 11:25 AM
beastmode's Avatar
Import Moderator
well see i already have the 16" AR Baja wheels from my old lifted blue truck, and i have the stock steelies, i dont plan on buying any racing wheels for awhile... i was just curious if there was something better that maybe i had in my parts bin ya know
Old Aug 3, 2007 | 04:24 PM
nightrunner's Avatar
Mr. Obvious
go wit the aluminum rims ya got now.
ya 20s are heavy, real heavy. if i could trade some one for some escalade rims and tires or 05 17s id trade straight up, i hate my 20s and i have no stockers
Old Aug 3, 2007 | 04:27 PM
u have any bigger pics with the black ones on your truck? i want to see em, plus want to get a pair
Old Aug 3, 2007 | 05:20 PM
AustinDesigns's Avatar
Put the aluminum ones on. Even if they are like 10lbs lighter, that's 20lbs of rotating mass that you are takin out. That's ALOT! Swap to the alum. ones, no matter what, they will help. I do know this though, stock 16" alum. with MT Drags are light as ****! I would still be using them if I hadn't needed a wider tire in the back. That's the only reason I ordered my Bogarts.
