Sh*t I Never Knew: Spacers On A Dually? Is That Safe?
Old Oct 26, 2017 | 03:01 PM
Custom Offsets's Avatar
Truck Platinum Sponsor
5 Year Member
Default Sh*t I Never Knew: Spacers On A Dually? Is That Safe?
We get a million questions on spacers, and recently this customers truck required a set of ¼" (6mm) Bora Spacers to prevent the rear wheels from rubbing. We ONLY sell and trust Bora Spacers. You can order any size, for any bolt pattern, with any hub bore you want at http://goo.gl/gZWZe1
Yes, WE RUN THESE on OUR trucks. Custom Offsets is a group of enthusiasts who use the products we sell.
The B.O.R.A. spacer is hub and wheel centric to create a perfect fit. This spacer will set the truck up just like a factory set up insuring a perfect ride. Anodized black spacer, grade 10.9 Steel studs, heat treated and zinc finished and lug nuts to bolt spacer to vehicle are included. These spacers come with a lifetime warranty. Made in the USA!
BORA Truck Spacers are manufactured right here in the USA with top-of-the-line, state-of-the-art, HAAS CNC machines, using only the best U.S. Alcoa 6061t6 billet aluminum. Unlike competitors, BORA provides a LIFETIME WARRANTY. BORA spacers will set your truck up just like a factory setup, insuring a perfect ride.
Lug nuts are made of 10.9 grade Steel, not stainless steel. The Open End Lugnuts we provide to attach our Adapter/Spacer kits are Cold Forged for increased strength and uniformity, our lug nuts meet or exceed OEM and aftermarket application standards. The Lug Nuts are backed by our ISO, QS and TS16949 Certified Facilities.
