rim issues
Old Feb 9, 2006 | 06:16 PM
nightrunner's Avatar
Mr. Obvious
Default rim issues
will a set of 22s off of a toyota tundra fit my 99 silverdo 1500 rcsb - same bolt pattern , backspacing, etc.? - and will i have any rubbing with or without a 3/4 drop
is 700 a fair price for wheels and tires?
Old Feb 9, 2006 | 07:28 PM
StrokerAce03's Avatar
If they're a 6 on 5.5 bolt pattern and hub-centric then they should fit. Whether they will rub or not depends on your backspacing and your tire size. I'm more familiar with 20's than 22's so maybe somebody with 22's will chime in.
Old Feb 9, 2006 | 10:57 PM
JoeJ's Avatar
I dont know what toyotas BP is. If its 6on5.5 they will fit. We are going to need to know the width backspacing, and tire size to know if you are going to have rubbing issues
Old Feb 10, 2006 | 04:09 PM
02BlueStepside's Avatar
Toyota does use the same bolt pattern, but the hub size isn't the same. I don't remember if its bigger or smaller than the chevy's. If it is bigger, that means it will not be hub-centric and if its smaller, it will not work.
Old Feb 10, 2006 | 06:34 PM
JoeJ's Avatar
just get some wheels that are meant for your truck IMO
Idryfly5
Sep 2, 2022 08:55 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
dselby25
Sep 11, 2015 05:03 AM
askkmb
Sep 7, 2015 10:58 PM
Sdailey
Sep 6, 2015 10:26 PM
