Removing Door Panels
Old Mar 17, 2004 | 01:53 PM
Lil_Quick's Avatar
Default Removing Door Panels
How do i remove the inner door panels on my truck to install speakers?? I tried to follow the instructions on the JSmith site but that is for electric windows. i Have manual windows and the window crank is the only thing i cant get past
Old Mar 17, 2004 | 03:32 PM
JSmith's Avatar
Are you having a hard time getting the actual crank off the post? You may need to go down to your local auto parts store and pick up a handle removal tool. You slide it behind the handle and it spreads the locking clip so you can remove it then your handle.
Old Mar 17, 2004 | 09:24 PM
Thumbs up
you can use a small screwdriver also to remove the little U shaped clip behind the handle, a little more of a pain in the a--, but free. As soon as the clip is pushed off the window cranks shaft it will want to go air born so keep an eye on it.
Old Mar 17, 2004 | 11:04 PM
Lil_Quick's Avatar
K thanks ill try that tommorow
Old Mar 18, 2004 | 11:26 AM
LOW2000's Avatar
You dont need any tools, take a shop rag and slide it behind the handle then slide it back and forth like you're trying to shoe shine the shaft that its on, the rag will grab the c-clip and pop it right off. The clip will usually have the open part of the C facing the handle. Takes all of about 3 seconds when you see what needs to happen.
FlyingLow
Nov 24, 2015 10:05 AM
cheyenne383
Nov 13, 2015 09:24 AM
rumblebox
Oct 29, 2015 10:35 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
