Removal of helper springs
Old Jan 8, 2004 | 06:45 PM
CHAGO's Avatar
Default Removal of helper springs
Going to try and remove them tomorrow.
Whats all involved/how long does it take, any tips etc etc
Old Jan 9, 2004 | 01:23 AM
454SuperSport's Avatar
pretty straight forward but remember to only do one side at the time and your gonna need some vise grips and some washers. the pin that holds the leafs together is too long when you take out the bottom leaf so clamp the leafs together (vise grips), remove the pin, pull off the helper, put the pin back in and use enough washers so you can get the bolt tight again. might sound like jibberish now but you'll know what i'm talking about once you get it apart.
Old Jan 9, 2004 | 01:40 AM
CHAGO's Avatar
FINALLY A REPLY! THANKS!
Old Jan 9, 2004 | 03:49 PM
StreetSweepa's Avatar
I just removed mine last week and like he said it's pretty straight forward once you get under there. Should take an hour or so.
Old Jan 9, 2004 | 04:01 PM
CHAGO's Avatar
Did it come down pretty good?
Old Jan 12, 2004 | 11:59 AM
should only help you a 1/2 inch
real easy to do....
you'll be done in under an hour
GXPJAY
Feb 13, 2022 08:15 AM
chopperloco
Jul 10, 2016 10:45 PM
jtphelps289
Sep 29, 2015 12:00 PM
chvy=power
Sep 8, 2015 11:06 AM
323steel36
Aug 25, 2015 05:11 PM
