Polish Aluminized Steel?
Guys, will aluminized steel pipes (http://intakehoses.com/Merchant2/mer...gory_Code=MIE0) polish up at all or is there no point? Doing the intake thing and will either polish and clear it if possible or paint it a gloss black or chrome.
Just putting some of your favorite metal polish on it and working it in a little will really make it shine. If there are some deep scratches, you may have to put some sand paper to it to get rid of them though.
I don't think that will work, that is a steel pipe with an aluminum coating (regular exhaust pipe), the aluminum coating is just to keep it from rusting, I don't think you can polish it.....
I couldn't find 45* 3.5" mandrel bent tubing like in the link, only straight. I guess I should say I haven't found a 45 degree with the same bend radius as the one in the link, plenty of 45's, just with tighter bend radii.
My bad, I read the aluminized as aluminum and skipped over the steel part.
Do you need the metal elbow, if not use a rubber/silicone elbow and some aluminum tubing from these guys http://airflo.com/index.html
Yeah, i need a 45* and 90* rubber elbow and a 45* metal bend. I'm going to look at lunch and see if I can find an AL one with a bend radius similar to the AL-steel one.
Superman09
Sep 25, 2015 05:55 AM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
