pics after 2/4 mcgaughy's drop
Old Oct 28, 2005 | 07:01 AM
smooth sierra's Avatar
Default pics after 2/4 mcgaughy's drop
I actually took these pics a couple weeks ago but figured I would share. Drop is the mcgauphys 2/4 spindles/hangers/shackles. Hankook ventus 275/45/20's. so far I am very happy with the look and ride and handling improvement.
Old Oct 28, 2005 | 07:07 AM
leochevy2001's Avatar
what shocks did you use? can you give me part #?
Old Oct 28, 2005 | 07:16 AM
I used kyb nitrogen gas shocks.......they are nice. Got em at cutten customs. Talk to troy. I wanna say they were $50 a piece. they are stiff as hell but I am told after they break in they will loosen up a bit.
Old Oct 28, 2005 | 07:26 AM
that sounds good.
do you bottom out in the back? my truck does but that could be due to the shocks.
Old Oct 28, 2005 | 07:33 AM
Fogle07's Avatar
truck looks kinda familiar. looks good. paint those mirrors next.
Old Oct 28, 2005 | 07:39 AM
going with some cal-vu mirrors next. slowly but surely it is getting more red
Old Oct 28, 2005 | 07:46 AM
Originally Posted by leochevy2001
that sounds good.
It was real bad before the shocks. After the shocks I have not bottomed out yet. One of my rear shocks was rubbing real bad, it had rubbed all the paint of one side of the shock. I must warn you, the kyb's are stiff. I wasn't quite ready when I cut the strap and well let's just say I was sore for 2 days after trying to recompress them.
New shocks will definitely help. I would do all 4 if I were you. they will make it handle much better also. You did cut down the factory bump stops right???? I cut mine down til there was only one rib left per the instructions. I have been told by others to remove the stops all together, but I am too conservative for that.
Old Oct 28, 2005 | 07:49 AM
my truck is heavy and it leans a lot when i am turning. did you get stock length shocks for the front?
Old Oct 28, 2005 | 08:14 AM
yes. the front shocks are stock length. try the shocks, they make a difference. mine does not lean at all.
Old Oct 28, 2005 | 09:58 AM
fluxu8's Avatar
Damn that looks good! What kind of wheels?
