painting engine cover
Old Sep 15, 2005 | 08:43 PM
green_z71's Avatar
Default painting engine cover
What do i have to do to paint my engine cover that says Vortec.
thanks
Old Sep 16, 2005 | 02:19 PM
Gran Patron's Avatar
I would think not that much work at all, if you just want a simple paint job just clean the cover make sure no dust or any resedue is on and paint it with your favorite color! It's a plastic part so the paint should stick pretty well!
I remember on my old truck I used one of those markers with permanent paint on it and it came out pretty descent!
Old Sep 16, 2005 | 06:11 PM
Mangled03gmc's Avatar
Baltimore Whore
Just like gran patron said. But if you want it smooth I would sand it a bit then prime it and sand then paint
Old Sep 16, 2005 | 11:34 PM
green_z71's Avatar
what grit of sand paper should i start off with and then what grit to use after the primer
Old Sep 17, 2005 | 12:20 AM
Make sure to spray on some adhesion promoter before you prime it. I started out with around an 800 grit, than sprayed it with another coat of primer, wet sanded with 1000 grit, than sprayed the color coats. BTW, if you don't wanna sand the plastic, just spray on some adhesion promoter and you can use a filler primer to get rid of the textured plastic.
Steve-O-08
Apr 19, 2018 09:32 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
USMCvet0311
Sep 30, 2015 10:34 AM
Denali08
Aug 9, 2015 04:34 PM
lsxmalibu
Jul 29, 2015 07:08 AM
