Paint gun and buffer questions?
Old Dec 15, 2008 | 11:21 AM
YenkoST's Avatar
Default Paint gun and buffer questions?
Looking for a paint gun and high speed variable buffer and looking for options....been looking at a few but really don't know what to get. On the paint gun, I know gravity feed is better on the paint gun but don't know what size spray needle to get and I know variable speed is the way to go but don't really know what rpms (assuming 4000-9000 rpms or around 7000 rpms for polishing after wetsanding). I know how to but just don't know the tools I used a long time ago.
Thanks.
Old Dec 15, 2008 | 11:44 AM
slownlow4.8's Avatar
when i did the auto paint i had a SATAjet 3000, it was a good gun
Old Dec 15, 2008 | 12:28 PM
KySilverado's Avatar
As a starter gun I bought a Devilbliss Finishline (I think). Its worked very well. Came with 3 different tip sizes... depends on what you are painting for tip size.
I'm not a skilled buffer so opted for the porter cable orbital.
My hood painting project... may touch on the gun in it.
https://www.performancetrucks.net/fo...=painting+hood
Old Dec 15, 2008 | 06:12 PM
02slow4.8's Avatar
how much do you want to spend?? I have heard the Devilbliss guns are pretty good guns, never used them. I have only used sata and my iwata. Sata guns are way over priced IMO. If you can get a deal, go for it because they are very good guns. I prefer my iwata over the sata guns i have used, it feels much smoother, less air pressure to get the paint to lay nice. It was expensive but cheaper than a satajet 3000
Old Dec 15, 2008 | 07:23 PM
Dominion's Avatar
If you plan on painting in the house the Devilbiss line is better than Sata. Sata requires 20 CFM to run, devilbiss only requires 9CFM.
I have been painting professionally for a few years and i use the Devilbiss Plus and the Devilbiss SRI which now can both be bought as a pair for well under $500
Check ebay.
Old Dec 15, 2008 | 08:05 PM
YenkoST's Avatar
Well...looking to primer and paint my own...yes. My brother is restoring a 1967 Camaro RS/SS original and I would like to paint a few odds and ends as I buy them.
I'll probably check out the Devilbiss then...see what they can do.
Old Dec 15, 2008 | 11:12 PM
95 bright teal's Avatar
+1 on Devilbliss, they make some good stuff!
Old Dec 16, 2008 | 08:11 AM
YenkoST's Avatar
Ok...how about the buffer?
Old Dec 16, 2008 | 08:30 AM
You can't go wrong with Porter Cable IMO. The biggest decision is whether to go orbital or not. Orbital is damn near impossible to ruin a paint job but slower getting the job done.
Old Dec 20, 2008 | 08:59 PM
silverod's Avatar
if you want an actual buffer not an orbital then go with a dewalt variable speed. I worked as an auto detailer for a while and that was the best I ever used. I always got the one with removable brushes for the motor. the wool from the pad gets in the buffer and the holes for the brushes are a good spot to blow them out so you dont have to tear it all apart
