orange peel and scratches RESULTS!
well i went back and spent another entire day buffing and polishing!
and i am very happy with the results
i did a 3m rubbing coumpound with wool pad, washed, then followed up with meguires #7 machine glaze so here you go, the first two are the befores!
Yep oh yeah forgot to mention, i have about 20 hours into it.
it doesnt help when you have to compound the entire truck twice, because you werent trying hard enough the first time
Tomorrow i will finish detailing it and i should have some more pics of the whole thing
Looks pretty good so far. I take it you were using a rotary?
I don't want to be an ***, but you need another polishing step to get the best results. That glaze is hiding a lot of the marring that the compound & wool pad left behind and it will probably show back up after the next wash. You need to polish the truck again with a polishing pad and a finishing polish to remove the remaining swirls.
Meguiars would call it a pure polish, meaning that it contains no abrasives and won't remove marring/swirls. A glaze or pure polish is meant to increase depth/wetness when used under a caruaba wax. Because of how oily glazes usually are they also tend to fill in swirls, which hides them temporarily.
It's a learning experience don't get frustrated to bad. Look at it this way once you get it right all you have to do is keep it up with a occasional clay/wax as long as it dosen't get any more scratches but in that case you will allready know what to do.
