ok...how bad is it???
Old Oct 21, 2006 | 04:30 PM
CONFUZED's Avatar
Default ok...how bad is it???
how quickly must i get a 2/4 drop? is it really that bad? i was told to get the 275/45s , it has 2in drop in rear already. what is the cheapiest/easiest way to do the 2/4 drop. need ballpark $$ fiquere and ease of install. in case you didnt notice, i am new to the truck scene
Old Oct 21, 2006 | 07:56 PM
02BlueStepside's Avatar
Doesn't have to be done right away, but of course it will look much better.
For the front you have several options. You can go with control arms for a factory like ride, but there will be a slight increase in bumpsteer. You can also go with spindles for a factory like ride, but you will increase your turning radius. The other option is to go with springs, but the ride will suffer some, it will be stiffer.
For the rear, since you already have shackles, you can just add hangers and get the full 4" drop. Another option would be to put your stock shackles back on and put on some hotchkis leafs, like up front though the ride will be stiffer.
Old Oct 22, 2006 | 12:41 PM
budhayes3's Avatar
PT's Slowest Truck
02 Blue pretty much covered all the bases, but is far as the question "how bad is it?", I don't think it's bad at all (definitely seen much worse). It'll definitely look better dropped, but in the mean time, I wouldn't be too self conscience about it
Old Oct 22, 2006 | 01:40 PM
Stoichiometric's Avatar
I agree, your truck looks good the way it is.
Old Oct 22, 2006 | 03:14 PM
TG02Z71's Avatar
I think it looks good. Don't get too hung up on having a slammed truck like the rest, someone has to be different, if we all had slammed trucks it would be boring too. Right??
Old Oct 22, 2006 | 05:36 PM
1badsilver's Avatar
It looks good. Leave it like it is for a while. Don't let the truck scene "pressure" you to think you have to do anything. Although it would look better......
Old Oct 23, 2006 | 10:15 AM
Siiverado44's Avatar
I think it would look good dropped, but I wouldnt mortage my house to get it done right away. I choose the Hotchkis TVS for my drop, and I couldn't be happier. The kit makes the truck handle superbly (for a truck) and alot more fun to drive. Yeah, it makes the ride stiffer, but it's only a problem for me on really long rides or when I have a hangover. And it's difficult to install, I had to remove my gas tank. Just some things to keep in mind.
Old Oct 23, 2006 | 03:58 PM
getchusum99's Avatar
i think it looks like , you should go with the 2/4 drop and the esky handles.ill help you do the drop , i promise not to break to much sh*t,lol.
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Chevy305
Sep 28, 2015 09:21 PM
