Need advice lowering my 2015 silverado
Old Oct 8, 2015 | 10:41 PM
Sam Owens's Avatar
Registered User
Default Need advice lowering my 2015 silverado
I have a 2015 Silverado black out edition 4x4 that I would like to lower. My question is how low can I go? Mcgaughys offers a kit for 4x4's but it is only a 3/5 kit.. I would love to do there 5/7 kit but it says it is only for 2wd.. Can I do a 5/7 drop on my truck?
Old Oct 8, 2015 | 10:57 PM
FFDP's Avatar
Can you, sure. Is it going to drive nice with 4WD equipment, thats another story.
Big problems are going to be cv axle angles and driveline angles.
I know some guy from canada did a 4/6 or 4/7 drop on his 4x4 sierra but I forget his name.
Old Oct 8, 2015 | 11:07 PM
Sam Owens's Avatar
Registered User
So how would you recommend approaching this if I wanted to do a 5/7 drop?
Old Oct 10, 2015 | 12:26 AM
Sam Owens's Avatar
Registered User
Anyone?
Old Oct 10, 2015 | 02:51 PM
Tig's Avatar
Tig
I've seen a few but they were NBS.
You may be able to get the front down with a coil-over conversion and do a flip lit out back with some shackles.
Like said, you'll more than likely run into problems with your CVs.
It would look killer though.
Old Oct 11, 2015 | 11:55 AM
Sam Owens's Avatar
Registered User
Are there any aftermarket CVs that would work?
Old Oct 11, 2015 | 07:24 PM
FFDP's Avatar
Different CV's don't correct the angle (they dont make anything other than stock anyway). Your front diff can't be moved.
Either coilovers up front if they make them for the K2XX or drop struts and spindles. I'm unsure if they make aftermarket lowering control arms for these new trucks yet. Then a flip kit in the back is simple.
Also note the ride will be kinda crappy if you run big rims with super short sidewalls.
Raffman
Jul 23, 2018 02:26 PM
FlowmasterMufflers
Nov 24, 2015 01:00 PM
Shotguntommy
Sep 15, 2015 05:24 AM
sprayed99
Sep 14, 2015 12:36 PM
GM1697
Sep 9, 2015 01:52 PM
