My custom built wheels!!!
Old Mar 12, 2009 | 03:52 PM
viciousknid's Avatar
Where's the Beef?
did you weld and balance that yourself or have someone do it?
IF you did, how'd you make sure it balanced properly?
Old Mar 12, 2009 | 04:10 PM
TXsilverado's Avatar
Originally Posted by GMCtrk
Toyo recommends 285mm max on an 8" wide wheel.
i have 305/45-18 555r's on an 18x8 wheel and they are wearing even and look fine.
Old Mar 12, 2009 | 04:27 PM
QLF's Avatar
QLF
x2
Most tire companies are going to tell you things like this to avoid liability issues. You can safely run a 12.5" tire on a 7" rim. It's going to be a little different pressure wise to get it to ride and wear well than a regular tire, but it is by no means dangerous.
Very nice wheels Regency! That's a really cool idea. I have seen it a few times in the past and I always wonder why more guys don't do this.
Old Mar 12, 2009 | 04:36 PM
MeanZ71's Avatar
Originally Posted by 00Silv4.8
Some tire shops won't put bigger than a 285 on 8" wheels. Just heads up.
Regency, do you not have disc brakes on the rear?
05+ are rear drums for half tons
Old Mar 15, 2009 | 07:22 PM
silver-mod-o's Avatar
Hunt&Fisherator
If everybody always went with the "manufacturers recommendations" wed all be driving stock ****...
Old Mar 15, 2009 | 07:28 PM
sixltrbtr's Avatar
Hahaha. Really!!
I'm interested in the steps you took to accomplish this myself. Looks really cool!
Old Mar 15, 2009 | 08:02 PM
ZR1 DREAMING's Avatar
Great idea!! They look like they turned out perfect.
Out of curiosity what do they weigh?
Old Mar 15, 2009 | 08:36 PM
regency's Avatar
No the 05's went to a larger front disc and a drum rear
I done it. We done one wheel at a time, balancing we used a dial indicator and would install the wheel and put it in gear and let off the brake and watch it to see if it was wobbling. By the time we were done, i had them balanced better than they were right out the box.
Im guessing about 25#
Old Mar 15, 2009 | 08:37 PM
regency's Avatar
Thanks fellas!!
Old Mar 17, 2009 | 01:19 PM
vanillagorilla's Avatar
So you used a dial indicator to check the run out as you tack welded them? That's pretty wild. It sounds like it would be very time consuming and tedious. I'm curious to know what wheel manufacturer's tolerances are for wheels and tires.
Oh yeah, how did you cut the welds from the hoop to the center section? That seems like it would be a PITA.
