More Color Matching and Sticky Suggestion
Old Dec 19, 2007 | 04:33 AM
viciousknid's Avatar
Where's the Beef?
Default More Color Matching and Sticky Suggestion
Might want to add this info as a sticky some day.
I'm getting bored and was gonna go ahead and paint my bumper cap, lower valance(again) and my dash bezel. all black.
Are these the proper steps to take?
Originally Posted by Chevy Cowboy
1. Clean peices with hot water/dish soap
2. Begin sanding with 180 grid to remove most of texture
3. Sand with 220 to get rid of "hairs"
4. Apply 2 coats of plastic adhesion promoter
5. 2 "light" coats of primer
6. Wetsand with 500 grit sand paper
7. Wash peices with hot water/soap
8. Paint with pewter duplicolour rattle can paint
9. Several coats of clear
also I have a set of door handles that have already been prep'd I just need to paint them. If i go get a can what color code do i get to make sure it's not like 4 shades of red off. Anyone know?
Old Dec 19, 2007 | 08:24 AM
BlackGMC's Avatar
Resident Retard
IMO use filler primer, not regular primer... At least that is what I used (Along with the adhension promotor) with my mirrors and front air dam...
Old Dec 19, 2007 | 09:55 AM
dirt track racer 81's Avatar
+1 for filler primer..have fun if your hand sanding these..takes hours..on my last piece i finally bought a small sander that does great with this..you can borrow it if ya want it
Old Dec 19, 2007 | 01:35 PM
Where's the Beef?
I have one that should work just fine.
Old Dec 19, 2007 | 01:45 PM
BlackGMC's Avatar
Resident Retard
Personally I would not worry too much about sanding down all the grains completely smooth. You really just need to rough it up enough to give it something to stick/grasp onto.. The filler primer will take care of the grains. Using the filler primer instead of sanding completely smooth will prevent Waviness in the outcome....
Old Dec 19, 2007 | 10:28 PM
budhayes3's Avatar
PT's Slowest Truck
What kind of sander do you have...will an angle die grinder work? (I have a die grinder)
Tydriver
45
Oct 23, 2015 09:19 PM
Superman09
Sep 25, 2015 05:55 AM
5.3lSilverado
Sep 20, 2015 06:48 PM
DrX
Sep 18, 2015 08:53 AM
